sony v, w, x series which one should i buy?
Discussion in 'Sony TVs Forum' started by jpb82, Dec 31, 2006.
  1. jpb82
    jpb82
    Nov 22, 2005
    800
    Rugby
    +18
    hi
    i have £2000 to spend on a new HDTV mainly to be used
    with the x360/ps3/hd-dvd/blu-ray/standard sky and probably
    pc gaming eventually its been extremely difficult trying to find
    the right tv but ive finally decided to go for a 40" sony lcd
    so the question is which one.
    as im spending a lot of money i want the very best PQ
    also as im quite a heavy gamer i would prefer to get a
    1080p set now i know that 1080p content is extremely limited
    right now but as most ps3 games will support 1080p and x360
    will probably support 1080p eventually i think it would be
    quite foolish to spend a fortune on a new tv that doesn't
    support 1080p i think its just better to be safe rather than sorry.
    now for which one to buy im not to keen on the sony 40w2000
    because of all the troubles this model is having with
    backlight bleeding + a few owners have just started to notice
    motion problems the sony 40v2500 is a possibility however it
    doesn't support 1080p that just leaves the sony 40x2000
    which is sony's flagship model and as its sony's most expensive
    model PQ should be the best also after reading reviews and
    comments from owners it appears that the sony x series
    is the most reliable out of all of sony's lcd's which is important
    so at the moment the sony kdl-40x2000 is my number one choice.
    if anyone has any advice on which sony 40" lcd i should buy
    i would really appreciate it also any other surgestions
    would be welcome.
    Thankyou
  2. Madmischief
    Madmischief
    Hi Bud
    I just bought the 40inch X series and love it. I got it for £2000 with a 5yr from my local sony centre after some tough bargaining with the manager.
    I have not tried the W series but the was little picture difference with the X on HD feeds when demoed to me in the store. I got the X because of the better reviews and cleaner design.
    I run it with a Denon 1930 dvd upscaler (1080P) ... it's just amazing and I would reccomend it to you thoroughly!!
    Go for the X series ... Happy New Year !!
    :thumbsup:
  3. Zigourney
    Zigourney
    Nov 26, 2006
    640
    Birmingham
    +313
    simple answer if you can afford it and like the looks of the x then its the x! if not the w! nothing else should even come in the picture!
    i have the W, and its kick ass! was gona buy the x but couldnt stretch the extra £500 at the time!
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    From what I've seen so far, no other model is going to be better, at least not significantly.
    Remember all LCDs still have some motion issues.
  5. Dazo
    Dazo
    Dec 17, 2006
    2,110
    48
    +73
    I have the 40W mate and the picture is truely excellent. Also don't be put of by motion blur backlight bleed as it really is not a issue for me or many others. This was my first LCD purchase and to be honest after reading some posts on here it can really put you off a model. A lot of people on here seem desperate to look for problems when they get a new tv instead of just enjoying it. I now have SkyHD but i was using normal Sky+ through scart and the difference in picture quality over my crt was instant. :smashin:
