Sony V Casio
dann
Hi am looking to buy a new camera & have narrowed it down to either of these:
Sony DSC-T30
Casio EX-Z1000
Can anyone tell me in there experience which one you recommend.
Dan
ufitsy
Have a look at Ken Rockwells site for Casio reviews.
http://www.kenrockwell.com/casio/ex-z1000.htm
He likes it but slates the movie mode although i hear Casio have a firmware upgade that addresses this. The Z850 warrants consideration, I have had a Z750 for 18 months and can't praise it enough.
While you are at the steves-digicams site go to the forums section there is a lot of model specific info there.
john
mg-paul
Got a Z1000 myself, which I tend to carry with me most of the time.
Very easy to use, but can also be manually controlled for some effective shots.
The movie mode I find is okay (not up to a true video camera but then it's not one).
The only issue I find is that the flash takes a long time to charge and you can miss shots because of it.
+ points
Great screen
Easy shooting modes
Manual override/controls
Can display/setup most key parameters from the "right hand menu" (can't think of a better way of describing it).
10M pixels
Shares the same batteys as my 600Pro
- points
flash seems slow to charge
10M means noise at higher isos
beachy
i had a casio ex-z50 just over a year ago, the photos where ok in normal light, but in low light pretty dismal, a friend of mine has that sony you mentioned and if i had to pick one out of those two, i would choose the sony.
Similar threads
