Sony USB HDD Recording
Cjbb
Why has Sony disabled USB HDD Recording on Android TVs in Australia? Is this just a software thing? Is it likely to reintroduce?
kenfowler3966
Its more likely to be a licensing issue. My first flat screen tv, an LG could theoretically record, but was disabled in the uk as LG couldn't agree terms with the freeview body. There were lots of people doing work arounds by telling the tv in its firmware that it was somewhere else in the world to enable recording, but it then didn't really work with uk programs
Mallett94
Do you have Youview enabled (or some equivalent)? On my set in the UK, with Youview enabled recording is disabled. However if you disable Youview and just use 'normal' freeview then you can record.
