AnthonyMonroe76
I hope this is the right place for this question, I am new to the forums.
Basically, I recently bought a new Sony UBP-X700 4k Blu-ray player, and I am having trouble playing Dolby Vision and Dolby Atmos simultaneously.
My first approach was to hook the Blu-ray player straight up to the my receiver (Onkyo TX-NR646), and then route that to my TV (Vizio M50 E1). The problem with this is that my receiver only accepts HDR10, not Dolby Vision, so I miss out on that.
My second approach was to hook the Blu-ray player straight to the TV, and then use audio return channel from the TV to get the audio to my receiver. With this method, Dolby Vision works, but I am left with some sort of Dolby Digital Audio (5.1 I think), but no Dolby Atmos.
The Blu-ray player has a second HDMI port for legacy receivers (I didn't think my receiver was legacy already, but here we are). With this, I can send Dolby Vision video straight to the TV, and Dolby Atmos audio straight to the receiver. The problem with this is that, for some reason, the receiver doesn't push any audio or act as if it is detecting anything from the input the Blu-ray player is connected to when the TV is set to the input that the Blu-ray player is connected to.
Oddly enough though, if I set the TV to the input the receiver is hooked up to, suddenly the receiver starts playing the audio from the Blu-ray player (in Dolby Atmos, no less). But I obviously don't see any video on my TV.
However, if I disconnect the receiver from my TV and set both my TV and receiver to their respective Blu-ray players, I get Dolby Atmos and Vision just fine. This is a pain though, as I use the TV's streaming apps through ARC to the receiver all the time (and not to mention that my girlfriend does as well, and while the setup without the Blu-ray player is pretty simple, even that can prove a struggle to her).
Is there something obvious I'm missing? Should I just use HDR10? Should I disconnect the TV from the receiver each time I want to use my Blu-ray player? Should I buy a Dolby Vision capable receiver? (I really don't want to do that). I've just found myself frustrated, as I was very excited to finally complete (for now) my A/V system, and came across this big hitch.
All advice will be appreciated. Thanks in advance!
