Sony TV's remote control stopped
Omartahhan2
Hello every one
I need you help
I have a sony bravia tv with android os x800h
Somehow it's remote control exposed to a micro wave waves .. and it stopped working after that ... is it possible that it stopped due this reason?!
If so .. how can fix the issue
I tried resetting the remote many times .. but useless.. no IR signal.
Thank you
JayCee
No, the microwave is unlikely to have broken it.
It's more likely that it's been dropped/had a fall and the circuit board inside has a crack in it.
I've got to ask...have you tried new batteries?
Omartahhan2
Thank you for your reply
I am sure that it hasnt been dropped... i also tried a new batteries.. still not working
I turned the microwave by mistake for one second while it was in it ( also by mistake :))
JayCee
You might have said it was inside the microwave!
You need to buy a new remote.
Omartahhan2
Yes it is bluetooth .. i tried to re pair it .. the problem is it is not sending IR signals
Is there any way to fix this ?
