Sony TV has gone mad!!
Discussion in 'General TV Discussions Forum' started by mjn, Jan 21, 2002.
  1. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,859
    My set has gone crazy...!!!
    Firstly the geometry has been getting worse along the bottom edge on 2.35:1 material....with a bow effect, making the border bigger in the middle of the screen, and thinner at the corners.
    Secondly, the TV will no longer switch to widescreen upon anamorphic DVD's, i have to change manually!
    Thirdly, the brightness has gone stupid, must be about 500% over what it should be....the picture looks like an over exposed photograph on all inputs, except RGB. Strange thing is, the teletext is ok on the channels??
    Is there a way of reseting the Tv to factory defaults to see if that makes a difference?
    please help!!
  2. DPJT78
    DPJT78
  3. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,859
    checked that site, and its mostly for the KV-32FX60... :(
  4. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,859
    update...the autowidescreen switching only works on R2 and not on R1....very strange..
    IS it a different pin to auto change widescreen modes for PAL and NTSC material??
  5. DPJT78
    DPJT78
    I think no.
    The auto format is tranfered by one of the 21 pins of the scart connnexion (I don't know if 'scart' is the correct word for 'peritel' in french') and the voltage in this particular pin changes from +6V to +12V for 16/9 autoformat (if I remember well).
    Maybe this particular pin is not connected (or no more connected) on your R1 connexion.
    Did you disconnect your DVD player recently or change the connexion from R2 to R1 ? because the welding of these connexions is very often fragile.
  6. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,859
    no changes were made to either Tv or DVD.......
  7. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    My Philips TV doesn't Anamorphic switch for R1 discs either, it never has. I've read somewhere that the switching signal is different for R1 and some TVs don't detect it....
    Did your set used to be OK for R1 switching?
  8. bob007
    bob007
  9. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,859
    yes my TV used to change on R1 DVD's.....and i will have a look at that guide..thanks
