Sony TV from Webelectricals
Discussion in 'Televisions' started by Stinky985, Feb 18, 2003.
  1. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    Just ordered a K32fx66 from Webelectricals. Anyone else bought from them?
    I was wondering whether it was supplied with a moulded 3 pin british plug.
    The sony DVD Player i got from them had a euro 2 pin plug and a 3 pin adapter already attached. Does this mean its an import???
    I would really not want an imported TVand think i would prefer to cancel and get a 'british version'.
    Someone help me!
  2. Bogside
    Bogside
    Sep 20, 2002
    3,005
    Stockport (ex Derry)
    +367
    Your dvd player is an import (or "grey" product) as they are called. Other things to look for are photocopied instructions, a model number that doesn't end in U (for UK), opened packaging etc.
    The product you are getting may still be OK but obviously it's best to get a UK spec one.
    Don't know much about webelectrical but do a search to see if anyone else has.
  3. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    All manuals etc were official in English and the box was 50/50 French/English though.
    Happy with the DVD player and too late for that so im stuck with it!
    I am going to ring them about the tv now and check.
  4. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    Just rang them and was told that they get the products from Sony Uk, Panasonic Uk etc and yet sometimes they sometimes have the euro plug and UK adapter supplied, sometimes not.
    Apparantley its the luck of the draw depending on what they get from the manufacturer.
    If its good enough for the manufacturer to send out then its got to be ok. All EU specs are the same and run on the same voltage so i suppose it is logical to build a standard and just give adapters to UK as we are different. Plus the price has to be taken into account too!
    My DVD player is great and i have no problems with it and the Sony Euorpean guarantee still covers the products, so it just a niggle until i see it in action i suppose.
  5. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Not true: Grey imports are those sourced outside the EU. Those from the EU are parallel imports and must meet all relevant safety standards etc and any warranty will still apply.
    As stinky said, in any case the voltage is 230V throughout the EU and manufacturers usually have a single spec for the whole area. Obviously it's a good idea to double check though. As for the adaptor ready fitted as mentioned by stinky, this indeed is common practice now.
  6. Bogside
    Bogside
    Sep 20, 2002
    3,005
    +367
    Sorry. I was generalizing.
  7. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    No problem, just thought I should clarify. ;)
  8. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    thanks i feel better now!
    Best part of a grand though and i was a little 'perplexed'!!
  9. w3dal
    w3dal
    Aug 4, 2002
    4,894
    Chelmsford, Essex
    +535
    Bought my fx66 from webelecticals back in november, and i have no complaints infact i have one of the better fx66 sets on this fourm, was perfect straight out of the box.
    Enjoy this tv, its fantastic!!
    Dal :D
  10. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    thanks for that - exactly what i wanted to hear!!
    :rotfl:
    cheers - i'll find out on Monday when its delivered!!:smashin: :zonked:
