Sony Tube Problem - White gone Purple
Discussion in 'Televisions' started by Trommel, Apr 28, 2005.
  1. Trommel
    Trommel
    Apr 28, 2005
    5
    I have an old (around 1996) Sony CRT TV which has developed a picture fault - whites and light colours are shown as varying shades of reddish purple. No amount of playing around with the picture settings changes it.
    Is this a common fault? Repairable, or am I off to the tip?
    Thanks in advance.
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    I couldn't tell you if it's repairable or not but it sounds serious. Maybe the electron gun has started pack-up(?)
    It is a very good time to buy a replacement CRT TV though. The retailers are almost giving them away!
  3. Trommel
    Trommel
    Apr 28, 2005
    5
    Thanks, I imagined it would be something similar. I wasn't really holding out any hope, just seems a shame to dump it...
  4. JayCee
    JayCee
    Jan 20, 2004
    19,737
    Lanarkshire
    +1,876
    It could be something serious or simple, what's the model no?
  5. twarde
    twarde
    Oct 11, 2002
    139
    2
    +12
    I had a similar problem on an older Sony set. I took it to the local TV shop. They said it was a "purity" fault and charged me £50 to fix it.
    You can search google on sony purity fault and theres a few examples from TV engineers websites.
  6. tvdoc
    tvdoc
    this kind of fault can be easily fixed by using a soldering gun withe set swiched on place gun near tube press swich on gun a move around tube move away from tube slowly and swich gun off . our turn tv onside for
    fewe minutes if this does not work Degauss circurit possibly faulty
