Sony TRV33 lenses?
garfy
Can you screw extra lenses on the sony trv33 , i.e. can you put a wide angle lens on it? How much are they?
I udertsand you cant with the TRV22 is this true?
B
Brian110507
Yes the TRV33 accepts supplementary lenses, whereas the TRV22 did not. According to the spec. I read the thread inside your lens is 30mm diameter and you require a lens with that thread, unfortunately they are not to common BUT fortunately step up rings and 37mm dia wide angle lenses are, what you need is something like :-
http://www.keene.co.uk/cgi-bin/codesearch.pl?3037
this screws to your camera and accepts this :-
http://www.keene.co.uk/cgi-bin/codesearch.pl?KGW05
You can get wider angle lenses but you begin to see distortion known as 'barrelling' if you go much wider.
These are just suggestions if you do a google search for something like "Wide Angle lenses" I'm sure you will find plenty of alternatives.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
