Sony TRV218E & DVD R
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by MURFER, Dec 13, 2004.
  1. MURFER
    MURFER
    I have this camcorder & was hoping to be able to plug it into the TV & play the footage back. Could I then record this to my DVD recorder as long as the DVD R was setup to record whatever AV channel the camcorder was playing through?
    Murfer :D
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,336
    Rainham Essex
    +2,433
    Yes, the output of a camcorder can be recorded by any recorder with a composite/S-Video input.
    If your camcorder has a firewire (aka DVport, iLink, ieee1394) output and your DVD recorder also has a firewire input then you can also use this and it will give the best results as the signal stays digital at all times.
    Mark.
  3. MURFER
    MURFER
    The camcorder only has an AV cable with It, yellow & black connectors to the tv & one that plugs into the camcorder. Will i need an S-video cable?
    Murfer
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,336
    Rainham Essex
    +2,433
    No, S-Video (if the cam has this socket) would offer better PQ but is not needed. It is used instead of the composite (yellow phono plug).
    Mark.
