Sony TRV 22 or Panasonic 60
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by barkercs, Jul 26, 2003.
  1. barkercs
    barkercs
    Helpppppppp
    Im stuck between a rock and a hard place on which camcorder to buy.........the sony has the better lense but the panasonic is small, has anyone got an opinion on which ones better
    Sony TRV 22 or panasonic 60
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Well I don't know these 2 camcorders, but it really is down to what you are after.
    My personal opinion is that the quality of the footage is more important than a slightly smaller cam. All camcorders these days tend to be fairly small & light, so a better lens IMO is the deciding factor.
    Mark.
  3. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    A better lens will be no good if the size of the camcorder means that you don't bother to take it with you!
    Would you really notice the difference in lens quality?
    woody
  4. CMcK
    CMcK
    Mar 18, 2003
    408
    Scotland
    +29
    The salesman in Comet said the same thing about the lens quality to me. But after the good lady and I tried a few cameras we settled on the Panasonic DS60.
    It was far more comfortable to hold, especially for her small hands, and I bought it for £330 ish from Empire.
    So far I have been very impressed with the camcorder - image quality is really good and the weight of the camera makes it easy to use over extended periods even with out a tripod.
