Sony Trinitron aspect ratio problem
Discussion in 'General TV Discussions Forum' started by couchsucks, May 4, 2007.
  1. couchsucks
    couchsucks
    May 4, 2007
    89
    I've got a problem with my Sony Trinitron 32" widescreen CRT (KV-32FX65U). Well, the first thing is that it's nearly 10 years old ;) but i've just bought a Sony DVR and all the time, the aspect ratio keeps switching from 4:3 to 16:9 and back, pretty much every minute. If you set it to 16:9 it alsmost immediately goes back to 4:3. This means that I can't watch anything on the DVR due to the constant switching. It's not the DVR's fault as it also did it on my previous DVR and any console I would put in it. I've turned off auto format and any options to do with aspect ratio but it still happens. Is there anything I can do? Thanks for any help you can give
    edit: someone has the same problem here http://www.avforums.com/forums/showthread.php?t=288588 and nobody answered them :I
    edit2:
    Okay, now i've found the answer :p http://www.agoraquest.com/viewtopic.php?topic=26042&forum=34 it's the third option down, under AV-setup. I'm really happy, it was driving me mad, almost bought a new telly. Hope this helps someone else
