Sony to Pana HS2 via Svid = distortion
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by irvspeed, Jan 19, 2004.
  1. irvspeed
    irvspeed
    Dec 2, 2003
    41
    When I am trying to copy from camcorder via SVid front(AV3) or rear(AV4) of my HS2 I get either a slight flashing of the brightness or a band of green or blue at the top of the picture. In slow mow you can see that it is sometimes every other frame or maybee every 4th frame. If I use the yellow phono connector instead the picture is fine but I prefere to use SVid. The cable is Ok if I plug it directly into TV. I tried using a SVid & Phono to scartscart adaptor on (AV1 in) but couldn't get that to work at all. I have tried every combination that might be relevant in the settinf menu. Has anyone else had this problem or any idea's how to get round it please.
