Sony TA-VE215 replacement centre speaker advice please
Discussion in 'Home Cinema Speakers' started by phil_w, Jul 4, 2004.
  1. phil_w
    phil_w
    Can anyone advise me on a suitable replacement centre speaker for the Sony TA-VE215 amp. I would prefer a horizontal factor which is a bit larger than the supplied one (same as the satellite speakers). My only concern is that the speakers currently attach with colour coded sony connectors. Would I need to snip the cable and attach a new wire to the existing sony end or do new Sony speakers come with the same connectors?
    Excuse my ignorance, but I would appreciate some advice from anyone willing.
  2. daz1840392
    daz1840392
    in answer i have a centre speaker a oblong shape and it has the same connections as the sattelites supplied with your amp,i have just come by the same amp as yours do you have a user manual wth yours , i have it working ok just wanted to know if i have it connected right any chance of photo copy of the manual?
    cheers let me know
