Quantcast
sony swf-br100 sub woofer with pc?
mrminibus
I have a sony swf-br100 which works via a wireless connection between the sub woofer and Sony tv using a usb dongle and 3.5mm audio plug into the tv, I would like to use this sub woofer with my pc and projector, is there any way I can run this fantastic sub woofer from my pc?
I would really appreciate your help if this is possible
shotokan101
Do you mean when playing movies etc. via the pc orfo you mean when watching broadcast TV as well ?
mrminibus
I have a pc for using YouTube, Netflix and gaming and wish to use this sub woofer for the sound if possible?
