SONY SVR-HDT500/1000 Freeview+HD PVR Master Thread
Discussion in 'Digital TV & Video Players & Recorders' started by sila1999, Jan 27, 2011.
Tags:
  1. sila1999
    sila1999
    Feb 11, 2005
    284
    43
    +104
    Just thought i would let you know that Sony are about to release a HD capable PVR for the UK market. These models are
    SVR-HDT500 500Gb HDD
    SVR-HDT1000 1TB HDD
    User manual located here
    System Transmission standards:
    DVB-T/DVB-T2
    Channel coverage:
    UHF: E21 to E69
    The above channel coverage merely ensures the channel reception within these ranges. It does not guarantee the ability to receive signals in all circumstances. The channels that can be received differ depending on the region.
    Recording format:
    DVB-T/DVB-T2: DR (Direct Recording)
    Inputs and outputs
    AUDIO OUT:
    Phono jack/2 Vrms/10 kilohms
    VIDEO OUT: Phono jack/1.0 Vp-p
    DIGITAL OUT (COAXIAL):
    Phono jack/0.5 Vp-p/75 ohms
    LAN(100): 100 BASE-TX Terminal
    HDMI OUT: HDMI™ Connector
    USB:
    USB jack (For connecting digital still camera, USB memory and external hard disk drive)
    General
    Power requirements:
    AC adaptor: DC 12 V 3.3 A
    SVR-HDT500: DC 12 V 2.2 A
    SVR-HDT1000: DC 12 V 2.3 A
    Power consumption:
    SVR-HDT500: 30 W
    SVR-HDT1000: 31 W
    Dimensions (approx.):
    320 × 50.5 × 231 mm (width/height/
    depth) incl. projecting parts
  2. petrev
    petrev
    Jul 4, 2007
    4,345
    TX Mendip - DHR8205: FW4.22 - M1.35Blk
    +1,015
    A few bits collected from other threads
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    So no analogue RGB output for quality archiving elsewhere.
    Unless a UK model will be equipped with scart ?
    Regarding digital copying via USB:
    Note that such saved files are tied to the machine and will not playback on any other device.
  4. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    That's it according to the online manual
    Note : The DigitalStream DHR exports will play back on other DS DHR machines
  5. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    The actual note from the manual says:
    The titles recorded on this recorder are compliant with the XFS file system and can be played on this recorder only.​
  6. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    The more I think about this the less likely it seems [ That a UK version would be scarted ]
    This fits in with the general move to remove all analogue connectors from new equipment by the end of 2012.
    Another industry move that will inevitably redouble efforts to crack digital security systems as it becomes harder to move stuff about.
  7. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    Hi Gav
    Quote from Argos Answers
    :confused:
  8. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    Normally - I'd favour what the manual says over Argos' information any time... but until we actually see one [ in the UK] I'll reserve judgement.
    Perhaps Argos actually had 'Hands on' but there's no guarantee.
    Here's another dealers 'pre-ad'. No mention of scart there.
    This one says NO [ RGB] scarts.
  9. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    Had confirmation - Manual is correct - No SCART.
    SONY Premium HD product for the Main Living Room TV
    BRAVIA Sync - HDMI CEC
    Pete
  10. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    There are big implications here.
    This is the first machine of what is likely to be trend in hardware releases over the next year or two... and potential purchasers need to be made very aware of the limitations.
    Those limitations are: No possible analogue copying of material from this box.
    Digital copying limited to storage elsewhere ... but the files will ONLY playback on this machine.
    When the machine dies, so do those recordings.
    On other words, no permanent archiving is possible from these machines.
    On that basis I will be recommending against them.
  11. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,472
    +498
    Point taken, but for those of us who just use these type of boxes for time shifting not an issue I suspect. Certainly not an issue for me. I plan on buying one of these when they surface, simply because having a lot of Sony kit I'm hoping/expecting a high degree of integration. In all my time of having Freeview PVRs I've only ever archived 3 items, and one of those items I archived I ended-up buying on DVD.
    I agree that this playback locking thing is generally a bad thing but I think that (a) it's part of a bigger trend and (b) most people won't care.
    Clem
  12. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,079
    +6,961
    Indeed there will be many users for which archiving is just not an issue, but I do not know anyone who likes having their options forcibly reduced like this.
    Using your own example, as a user for whom archiving is not important, there have still been three occasions, where in future you will have no options.
    I do think this is an unhealthy shift in the balance of control of broadcasters/ content producers / hardware producers.
  13. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    Thin end of a mighty big wedge - Methinks !
    We shall have to see how bad it is when the box actually arrives, as while the Humax encrypts HD to the one original box, the DS encrypts HD but it will playback on other DHR machines and SD is clear when exported to USB for both.
    Wonder when it will arrive on these shores ?
    Pete
  14. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    Just spotted that like the DS it has MHEG iPlayer built in
    From SONY Support Answers
    Wonder if this means that Freeview HD MHEG iPlayer is imminent ? ? ?
    Pete
  15. Geoff_D
    Geoff_D
    Feb 14, 2005
    11,848
    167
    Spider Skull Island
    +5,792
    Sony have recalled the SVR-HDT500 due to an "issue with playback". Sony's last attempt at a PVR was an utter disaster - culminating in the machine recently losing the EPG completely due to software issues - and it looks as if the HD version is no different. Way to go big S. :thumbsdow
    Oh, in case you didn't know, an HDMI cable comes with it and retailers aren't too happy about this. Sony have said that including the HDMI cable in the box was an aberration (blaming Humax in a roundabout way) and is definitely not a change in policy.
  16. clemenzina
    clemenzina
    Jun 25, 2006
    1,542
    SW London
    +135
    I was hoping that hackers were going to rescue us from the HD archiving/playback restrictions. Naughty of me, I know - but it's naughty of "them" to be so mean :mad:
    On another aspect - will the HDT500 not need an £80 Sony-only dongle like their TVs etc do?
  17. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    Have you got the source link for this ? Seems odd that it is recalled before it has been released ?
    All the sales sites show end of Feb/early March as the ETA
    I thought the previous Sony PVR lost the EPG because the third party provider stopped broadcasting it.
    Ref: 4TV interactive programme guide. The company responsible for broadcasting the EPG (INVIEW) have stopped doing so, permanently.
    Pete
  18. sila1999
    sila1999
    Feb 11, 2005
    284
    43
    +104
    Sony did manufacture the SVR-HD700/900 which had twin HD tuners that was released at the same time as the SVR-S500. Although this was primarily sold in Australia it would work in other countries.
    Since that time they have not been selling anything outside of Japan or the US, surely that can go to their OEM partner and get them to make something that would work would wide like their current Bravia TV's can.
    If anyon does have one of the SVR-HDT models are they able to create a discrete code listing of the remote control.
  19. Geoff_D
    Geoff_D
    Feb 14, 2005
    11,848
    167
    Spider Skull Island
    +5,792
    There's no source link that I can give you, as (for my sins) I work in a Sony Centre. We had two T500 units in on Monday, the first email about the problem came an hour later and the recall was issued the next day.
    Sony may well be giving out the late Feb/early March lead time to give them a chance to recall & repair the units that are already in the wild.
    And regardless of how the EPG went from the SVRS500, it still doesn't do what it's supposed to do. Sony recognised how much of a balls-up this was by offering owners a cut-price RDRDC100.
  20. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    OK, but I still think you are being a bit harsh about the EPG - Sony like others bought a 3rd party EPG system at a time when there was only Now+Next for most boxes so they were adding something extra. Years later the third party stops broadcasting the service and like the other boxes that used it, they all revert to Now+Next only.
    My perfectly good On-Digital boxes stopped working after DSO as the transmission system changed. Pain in the neck to have to get a new box with RF modulator for the kitchen telly that has no SCART but that is the way of the Digital World. :(
    Next SD will go T2 and all the SD boxes will be redundent ! ! !
    Wonder how long before the SVR-HDT500 is back ?
    Pete
  21. Captainkremmen
    Captainkremmen
    Oct 22, 2010
    460
    28
    Wakefield
    +69
    Are any DS owners thinking of purchasing the Sony when they are launched?.
    Given the similarities (similar features, same file system etc.) it would be interesting to see if material archived to an external USB drive can be played back on the other machine. I wouldn't expect it to work, but might be worth a try.
  22. AlexS
    AlexS
    Oct 25, 2010
    156
    +19
    I was hoping Sony would release a FreeviewHD PVR for ages.
    Since Sony seems to be favourable to streaming content via their Bravia kit, the idea was to stream recorded content from the PVR downstairs to my Sony SMP-N100 in an upstairs bedroom.
    It appears I'm living in a dreamworld.
    I've probably got more chance of achieving this kind of setup with the DS DHR8205U I bought in January and a DS DPS-1000 unit...
    I'm usually a fan of Sony but sometimes their thinking confuses and frustrates me...
    ie BBC iplayer in SD/HD on Blu-ray but only SD on Bravia TV.
    BBC iplayer, ITV player & 4oD on PS3, but not on their mainstream Video products.
  23. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,472
    +498
    Yes, me. The CEC HDMI feature, DD5.1 audio over HDMI, and the fact that I have Sony TV, blu-ray player and Freeview PVR would seem to make sense to me. I'm sure the Sony box is an OEM from somewhere, but I don't really care providing that it works as advertised. I like the DS, but there are some features missing (DD5.1 over HDMI for instance) that mean that the box will never be 100% for me.
    Clem
  24. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    Hi Clem,
    Can you check with your DHR connected to your amp via HDMI as I have had an eMail from DS-K Engineers saying that the DS DHR8205 does do DD5.1 transcoding via HDMI - It should auto detect during boot (or something) and if the attached HDMI device is DD decoding enabled will provide DD5.1 as needed.
    I can't check this as I have no HDMI equiped Amp and my Sony isn't passing through DD5.1 via SPDIF so I can't tell etc. . .
    Pete
  25. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,472
    +498
    Pete:
    Holding-off as it looks like it's real DD5.1 rather than transcoded. So close, yet so far ..... sigh.
    Clem
  26. Already Taken
    Already Taken
    Oct 5, 2008
    146
    +10
    Argos and Play now have these listed as coming on the 1st March.
    I'll be interested to see how they compare to the Humax - a bit more competition in the market can't hurt.
  27. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,472
    +498
    I'm deffo up for one, given the reports her I'll wait for someone else to try one out first. :D
    Clem
  28. tdcist
    tdcist
    Jul 6, 2010
    12
    I have one... Gearing up for the Freeview HD switch on (April the 13th for my region)
    love the fact i can record 2 things at once too!
  29. Stuart P
    Stuart P
    Apr 16, 2005
    2,117
    +172
    really. purchased from where?
  30. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,472
    +498
    Yes, tell us more!!!!
    Clem
