Sony Stylish 20/23/26b4030-b4050 Models
Discussion in 'Sony TVs Forum' started by ChrisGgr, Jan 18, 2008.
  1. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    What do you think of these new stylish portable sets?Available at 20",23" and 26".The B4030 is in silver while B4050 on mocca glossy
    B4030
    [​IMG][/URL][/IMG]
    B4050
    [​IMG]
    SPECS
    Features
    Please be aware that the features/specifications can differ from country to country
    * Portable LCD TV with easy-to-carry rear grip
    * Bravia Engine picture technology for enhanced depth, clarity and definition
    * Bravia Theatre Sync enabling you to operate your TV and entire home cinema system by pushing one single button
    * HD Ready for the display of High Definition signals, i.e. Playstation 3, Blu-Ray, etc.
    * 2 x HDMI inputs for easy connectivity - 1 on rear, 1 on side
    * Built-in Digital TV terrestrial tuner (also receives analogue)
    * BBE ViVA high quality sound and built-in Virtual Dolby® creating the effect of full surround sound from just 2 front speakers
    * Audio Description compatible allowing for blind or partially sighted people to follow television programmes
    * Available to buy from November 2007
    Technical Specifications
    Please be aware that the features/specifications can differ from country to country.
    Collapse All
    Accessories
    AC Cable
    YES
    Coax Cable
    YES
    Operating Instructions
    YES
    Table-Top Stand
    Built In
    Remote Commander
    RM-ED009
    Table Stand Supplied
    Built In
    Audio
    Digital Amplifier
    YES
    Power Output (W)
    10W + 10W (Total 20W)
    Sound Mode
    Dynamic/Standard/Custom
    Steady Sound
    YES
    Virtual Dolby
    YES
    Auto Volume Adjustment
    YES
    BBE ViVA
    YES
    Speaker Off
    YES
    Colour System
    NTSC 3.58/4.43 (Video In)
    YES
    PAL
    YES
    Secam
    YES
    Connectors
    HDMI
    YES
    HDMI 2
    YES
    PC Input (15pin D-Sub) + Audio In
    YES
    Component
    YES
    4 Pin (Y/C) In
    YES
    MiniJack (Head/Earphone) (mm)
    3.5
    PCMCIA Card Slot
    YES
    RCA Audio Out
    YES
    RCA AV Input
    YES
    Scart 1
    YES (RGB)
    Scart 2
    YES (RGB)
    Bravia Theatre Sync
    YES
    Dimensions
    Depth (incl. Stand) (mm)
    167
    Height (incl. Stand) (mm)
    464
    Width (incl. Stand) (mm)
    666
    General Data
    Colour
    Pearly White
    Power Consumption (Standby) (W)
    0.7
    Power Consumption (W)
    90
    Menu
    On Timer
    YES
    OSD Menu
    YES
    Parental Lock
    YES
    Sleep Timer
    YES
    Menu Languages
    Bulgarian Menu
    YES
    Czech Menu
    YES
    Danish Menu
    YES
    Dutch Menu
    YES
    English Menu
    YES
    Finnish Menu
    YES
    French Menu
    YES
    German Menu
    YES
    Greek Menu
    YES
    Hungarian Menu
    YES
    Italian Menu
    YES
    Norwegian Menu
    YES
    Polish Menu
    YES
    Portuguese Menu
    YES
    Romanian Menu
    YES
    Russian Menu
    YES
    Slovakian Menu
    YES
    Spanish Menu
    YES
    Swedish Menu
    YES
    Turkish Menu
    YES
    Response Time
    8 msec
    Backlight
    CCFL
    BRAVIA ENGINE
    YES
    Demo Mode
    YES
    Input Skip
    YES
    Picture Mode
    Vivid/Standard/Cinema
    Theatre Mode
    YES
    Power Saving + Picture Off
    YES
    14:9 Mode
    YES
    16:9 Mode
    YES
    4:3 Mode
    YES
    AFD (Auto Format Detect)
    YES
    Auto 16:9 (line 23)
    YES
    Auto Noise Reduction
    YES
    Digital Comb Filter
    YES
    Display Resolution (Pixels)
    1366 x 768
    Display Technology
    LCD
    Picture In Picture
    YES
    Picture & Picture
    YES
    Screen Aspect Ratio
    16:9
    Screen Size (cm)
    Screen Size (inch)
    26
    Smart Mode
    YES
    Wide
    YES
    Zoom
    YES
    Sound System
    B/G
    YES
    D/K
    YES
    I
    YES
    L
    YES
    NICAM
    YES
    Teletext
    Digital Text
    YES
    EPG (NexTView/Digital EPG)
    YES
    Text Page Memory
    700
    Timer
    Clock
    YES
    Sleep Timer
    YES
    On/Off Timer (with Clock setting)
    YES
    Tuning
    Analogue Terrestrial Tuner
    YES
    Digital Terrestrial Tuner
    YES
    Favourite Channels
    YES
    Channel Coverage CATV
    S1-S20
    Channel Coverage HYPER
    S21-S41
    Channel Coverage UHF
    E21-E69
    Channel Coverage VHF
    E2-E12
    Channel Skip
    YES
    No. of Tuners
    Station Labelling
    YES
    Video Signal
    576i
    YES
    480p
    YES
    576p
    YES
    1080i
    YES
    720p
    YES
    ONLY THE 26" HAS 2X HDMI,the 20" and 23" have 1
