Sony STRK880
Discussion in 'AV Receivers & Amplifiers' started by bazlington, Dec 26, 2006.
Tags:
  1. bazlington
    bazlington
    May 22, 2006
    37
    How would I connect my sky plus box to my Sony STRK880? I would be looking to use the HDMI out from the Sony STRK880 to my plasma.
    Chris
  2. hulleyrob
    hulleyrob
    Dec 15, 2006
    79
    IOM
    If its your only HDMI device then why bother? Save yourself a cable and connect it direct then use optical out to connect to the amp.
    If its not the only device then can you give more details.
    Rob
  3. bazlington
    bazlington
    May 22, 2006
    37
    I am thinking of buy a Sony STRK880 to cut down on the amount of cables going up to the plasma. I was under the impression that I could connect my sky+ & dvd with hdmi out to it and just send one hdmi cable up to the tv.But because the sky+ is obviously not HD out...will the Sony STRK880 upscale the signal from sky+. I think it is RGB out from sky plus.
    Chris
