Sony STRDH520 & Toshiba Projector
gohardtech
I am using the Sony STRDH520 with a Toshiba Projector.
The projector can only accept Component RGB.
If I come into the receiver with HDMI Signals, can I send the output to the RGB or only the HDMI?
I hope that makes sense.
PSM1
There is no receiver that can convert a HDMI input to a component or composite output. There are receivers that go the other way (from component to HDMI- called upconversion) but none that do the way you want. I believe it is against HDMI licencing or something similar. What you need is a HD Fury as this will do what you want.
