Sony STRDG520 or Onkyo HT-R518
Discussion in 'AV Receivers & Amplifiers' started by Yidaddicks, Feb 7, 2009.
Tags:
  1. Yidaddicks
    Yidaddicks
    Feb 7, 2009
    4
    welling kent
    Hi, im a home cinema virgin :D I've had an all in one system for about 2 years and i think its about time i joined the world of av receivers. I have bought the Q ACOUSTICS 1010I speaker package and im looking to buy either the Sony STRDG520 or the Onkyo HT-R518, i know these probably arn't the best but im on a budget and its just to get me started. I would love it if you could give me your advice and views on which one would be best. I will be connecting my PS3 and sky HD. I would also like to know what is the best way to connect my PS3 and sky HD for audio, digital optical or digital coaxial. Thank you very much Dan.
    :lease: HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    Not sure about those models, but for your other question:
    Ps3 doesn't have a coax output so you will have to use optical. SkyHD (if its not a thomson) will have the choice, but there should be no difference as its the same signal outputting on both.
  3. Yidaddicks
    Yidaddicks
    Feb 7, 2009
    4
    welling kent
    Oh yeah silly me! Thanks for the advice mate :D
