Sony STRDE597
Discussion in 'AV Receivers & Amplifiers' started by Biccy, Jul 5, 2004.
Tags:
  1. Biccy
    Biccy
    :lease: Hi, can anyone help?! I am looking at new Sony HTDDW860 home theatre package that comes with the STRDE597 receiver. I will only get if the receiver decodes DTS ES 6.1 but some websites say it does this & some dont, even Sony (helpline) aren't 100% sure. If anyone owns this receiver i'd be really appreciate knowing little bit about it. Thanks, James :lease:
  2. Stopey
    Stopey
    The manual says it can. However, so far I can't get a single sound when I choose DTS. Dolby Digital works fine - haven't tried a 6.1 movie though.
