Sony STRDE445 or Yamaha RXV396RDS ? Any other budget DD receivers?
Discussion in 'AV Receivers & Amplifiers' started by GaryJ, Jan 22, 2001.
Tags:
  1. GaryJ
    GaryJ
    Help! I'm looking to buy a Dolby Digital receiver for about £200. (Should I be looking at DTS also?)I know my choice is limited but I've had quotes for the above two for around £200. Which is the best? I can't find reviews for either piece of kit.Should I be looking at any others? I don't mind second-hand but can't seem to find anywhere dealing with this type of kit. Can anybody help? Sorry for so many questions, thanks in anticipation,
    Gary J
  2. bhowe
    bhowe
    Be careful with the Sony. I have that model,and it is limited by only 2 digital audio inputs. An Optical and a coax. I can't get them to both work at the same time.
    Bill
  3. HCK
    HCK
    Oct 21, 2002
    740
    46
    West Yorkshire
    +116
