Sony strdb930 no surround sound.
Discussion in 'AV Receivers & Amplifiers' started by cdb, Jul 27, 2004.
Tags:
  1. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    I think my receiver may have finally died as far as the rear speakers go. There has been a (intermittent) clicking from the amp for a while, a relay of some sort maybe?? Does anyone know if there is a common fault on these (old) amps? I'll probably take it to the local repair man, but it would be good if I could give it to him and say compnent X needs changing. :)
  2. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    I think it's died. I have no surround and have lost the front left speaker too :S
    Anyone come across this problem?
  3. richgtfc
    richgtfc
    Feb 14, 2003
    129
    19
    Edinburgh
    Not quite, but my STR-DB1080 started making clicking noises on all speakers which got steadily louder. This was after only 4 months. Eventually...got it repaired under warranty, took nearly 6 weeks IIRC. It was the power supply thingy that was knackered. It's been OK for the last 12months..........
    Rich
  4. Jackam
    Jackam
    Depends how confident you are, but my 930 started to hum loudly in the rear speakers recently, so I whipped the lid off and reseated the many ribbon cables, multipoint connectors and fuses. All seems to have settled down now. Might be worth a try?
  5. Steve T
    Steve T
    Aug 30, 2000
    438
    Redditch
    +3
    My STRDB940 has also been losing the centre speaker intermittently for about the first half hour or so after switching the thing on. I also get the clicking noises. It's a few years old though, so was thinking of upgrading anyway, unless it proves inexpensive to fix?
  6. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    Sony STR-DB930
    look in the manual, follow the reset to factory settings proceedure.
    I have recovered my rear channels twice by doing that.
    Both my speaker losses happened after my 3 year old had unsupervised access to the amp, so there is clearly some combination of buttons that confuses the thing.
    When the speakers are in their non-working mode, they can squeak, hiss and click and generally make "my cones are ripped" noises.
