Sony STRDB930 LFE cutoff
Discussion in 'AV Receivers & Amplifiers' started by FunkyMonkey, May 12, 2003.
Tags:
  1. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Is it possible to set the LFE cut-off on this reciever? I need to ensure my sub and satellites are in balance and I'm not swampign any particular frequency. Thanks.
  2. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    It's a while since i used a 930 but i think it's fixed on the 930 at 120Hz.
  3. Grimley
    Grimley
    I don't think it is. I owned a 930 for a little under a year & AFAIK it had variable LFE cutoff. Best check its manual under 'Multi channel surround setup' if you still have it
    HTH
  4. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    Apologies...for getting this wrong...old age!
  5. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    are you sure it's variable on the 930 ... I don't remember ever seeing any way to change it on mine.
  6. Grimley
    Grimley
    I have the 940 & the freq. cut offs are variable on that, but I can't remember if its the same on the 930. I never really adjusted the settings on it that much. I left it on auto all the time I used it & just tweaked the individual volume settings a little. I never bothered with freq. cut off settings back then, I didn't think it would make a great deal of difference with my system.
  7. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    Me neither but Grimley seems sure and to be honest i only think the 930 didn't because when the 1080 arrived i noticed the LFE cut was variable...odd logic but there you go. With the main/surrounds set to small the crossover default was 120Hz, again from recollection, so even if the LFE cut is fixed at 120Hz it shouldn't be too problematical.
  8. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Hi all. Looked at manual last night. There is no mention of the cutoff. All I can see remotely relatign to it is the digitally controlled equaliser controls, but this isn't the same is it?
    The only sentence of note in the manual goes somethign like this:
    "To make maximum use of the LFE effects, set your subwoofer cut-off frequency to eh highest possible".
    I did this and NOW my sofa shakes. WOW, what a difference! Strangely I can still get the same lowish frequencies from my main speakers so I'm not sure what's going on in stereo mode.
    Anyway, I'm happy with music and movie sound and special effects now, so as Tuffers said, "happy days". :)
  9. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    In stereo the sub should not be recieving a signal - try AFD for that.
