Sony strdb930, built in crossover?
Discussion in 'AV Receivers & Amplifiers' started by cdb, Mar 1, 2003.
Tags:
  1. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    Having had my sony amp for a few years now, I've only just realise that the bass signal is going to the front speakers as well as the sub woofer. On a test cd from a car mag a33hz signal is torturing my mission 773es . I thought if I had a sub connected to my amp all the bass should go there. Have I missed something when I set the amp up? I can't find a small/large speaker setting.
  2. mjn
    mjn
    May 24, 2001
    22,235
    Herts, England
    +10,072
    the 930 has large and small speaker settings, and if you specify a sub in the setup, then LFE will go to that.
  3. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    I think I've found it. They were set to large, so I set them to small and that has sent most of the 33hz to the sub. I think there might be abit of leakage tho, because there is still some bass trying to come from the front 3 speakers.
