Sony STRDA 5500 Upscaling ?
Cloverleaf
Guys
Although I am really pleased with my Sony, one thing I find a bit annoying is that it will only upscale video from an analogue connection, ie not via HDMI ?
My question is in 2 parts I guess:
If I wanted to upscale Standard Def Sky for instance via my amp, is the only way to do this to get an RGB-Component converter, then outputting the component signal to the amp which can then upscale and output via HDMI ?
Secondly, assuming this would work, would there be any benefit in doing so ? Would the amps scaler be any better than the Sky box or TV scaler ?
PSM1
I would just stick with what you have. Your tv or box will upscale as well as the amp anyway.
Cloverleaf
Thanks PSM
LG CX 4K OLED TV Review: The best TV of 2020?
