sony str va55es
Discussion in 'AV Receivers & Amplifiers' started by Leom, Feb 27, 2003.
Tags:
  1. Leom
    Leom
    Feb 27, 2003
    20
    Australia
    Hi guys just wondering if anyone has come across this problem. My amps blue multichannel light doesnt always come back on after fast forwarding or skipping chapters, ive checked all the settings and am sure there all ok.Im using a digital coax cable and tried another one still the same problem.Havent yet upgraded from version 1.4 to 1.74.
  2. I am maximus
    I am maximus
    Nov 14, 2000
    76
    Surrey,UK
    U have answered your own question ,mine did the same until the upgrade it took two weeks at Sony to do.I hope this helps
    I am maximus
  3. Leom
    Leom
    Feb 27, 2003
    20
    Australia
    Thanks Maxximus I will try and get the upgrade done.
  4. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
  5. Leom
    Leom
    Feb 27, 2003
    20
    Australia
    Hi guys sorry Ive taken so long to reply . I got the 1.74 upgrade but the problem still occurs. Im starting to think it must be either a loose wire or the processing which tells the blue light to come on is'nt doing it properly as I said before everything seems to be working ok.Also does the upgrade just tell the amp to auto 6.1 decode.does it do anything else.
