Sony STR-VA555ES help please....
Discussion in 'AV Receivers & Amplifiers' started by DJBlade, Dec 30, 2004.
Tags:
  1. DJBlade
    DJBlade
    Oct 24, 2002
    1,402
    Halifax
    +101
    Hi, i've recently redecorated my room, and sunk my centre speaker into the chimney breast, directly under my plasma screen, looks superb, and works quite well.
    The prob i'm having, is that the speaker is slightly booming, so i want to redirect the bass, either to the fronts, or the sub, can someone walk me through this proceedure please, as the handbook is not clear at all.
    Thanks in advance.
  2. morksbeanbag
    morksbeanbag
    Jul 25, 2004
    723
    Chesterfield, Derbyshire.
    +49
    Only thing i could suggest is either setting your centre speaker to 'small' in the setup menu, not brilliant.
    However, it sounds like your centre speaker is rear ported. Try getting either a foam bung or a pair of socks rolled up and put them into the port to stop the boomy bass.
  3. DJBlade
    DJBlade
    Oct 24, 2002
    1,402
    Halifax
    +101
    no, its front ported.....
