Sony STR-VA555ES firmware update
Discussion in 'AV Receivers & Amplifiers' started by cybersoga, Dec 30, 2002.
Tags:
  1. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Has anyone got hold of the firmware update files (7.4 or later) that fixes the odd 6.1 detection problem with some titiles? I don't really want to send my unit away when I can do it myself. My unit has 1.4 firmware.
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I phoned sony asked for technical support and got through to some woman who said they don't support that model! *bangs head against table* has anyone had theirs updated? how long did it take? could I possibly get it done while I wait?
    Sony Service Center (Heathrow) 020 8283 2700
    Unit 2, The Heathrow Summit Centre
    Skyport Drive
    West Drayton
    Middlesex
    UB7 0SU
    Here are a couple of threads on Home Theater Forums discussing the issue:-
    Sony DA5ES and DTS-ES Discrete
    Where to get firmware-update for Sony 5ES?
    Thr DA5ES is the same machine as the STR-VA555ES apart from the PSU.
