Question Sony STR DN1050 Speaker Rattle
Discussion in 'AV Receivers & Amplifiers' started by Sher123, Jul 29, 2016.
  1. Sher123
    Sher123
    Jul 14, 2007
    57
    +5
    I have a 5.1 speaker set up plus two front high speakers. I've started to notice a ticking noise and then rattle from the two front high speakers every few seconds. It does not change if the volume is increased/decreased. Can anyone please suggest how to fix this or what could be causing this issue?
  2. Sher123
    Sher123
    Jul 14, 2007
    57
    +5
    Anyone?
