Sony STR-DG820 sound distortion
Discussion in 'AV Receivers & Amplifiers' started by pure_geordie, Feb 2, 2009.
Tags:
  1. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    Hello, Just thought I'd post this, I have this Amp and have started to notice distortion mainly on my rear speakers. I Have the Tannoy HTS200 speakers.
    Anybody else having similar issues with distortion on this Amp. Or could tell me what might be causing it?
    Could it be the crossover settings on it, They are set to small as well. It wasn't playing that loud either.
    Could anybody help in deciding what setting's to have setup on my Amp. I Used to have the DG-910 no problems but this Amp since I've used it seems not as good, I'm now asking myself why did I change it.
    These are my specs for my speakers:
    Specifications for the Tannoy HTS 200 5.1 Speaker Package
    Satellites
    Frequency Response +/- 3dB 100Hz - 40kHz
    Sensitivity (2.83 volts @ 1M) 87dB
    Nominal Impedance 6Ω
    Recommended amplifier power 25 - 100W
    Crossover frequency 3kHz (low to high)
    Shielding Yes
    Drivers 1x 3" (75mm) mid/bass paper cone
    1x ¾" (19mm) titanium wideband dome with neodymium magnet system
    Towers
    Frequency Response +/- 3dB 80Hz - 40kHz
    Sensitivity (2.83 volts @ 1M) 88dB
    Shielding Yes
    Drivers 2x 3" (75mm) mid/bass paper cone
    Centre
    Nominal Impedance 8Ω
    Shielding Yes
    Subwoofer
    Continuous output power 100W
    Frequency response 29Hz - 200Hz
    Crossover frequency 50Hz - 200Hz
    Inputs LFE Line or left/right speaker level input
    Frequency response 45Hz - 140Hz
    Driver 1x 8" (200mm) long throw paper cone
    Thanks.
  2. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    I've sorted it, after fiddling around with the settings:D
    Had my rears pumped up too much on my amp. Just tweaked slightly.
