SONY STR-DG510 Component in > HDMI out???????
Discussion in 'AV Receivers & Amplifiers' started by garagekru, Jan 15, 2008.
Tags:
  1. garagekru
    garagekru
    Oct 14, 2007
    23
    3
    Hi alol ive just bought a SONY STR-DG510, to connect my ps3 and xbox 360 up for some surround sound!
    I want to output to my TV through the HDMI socket!
    The ps3 which is pluggged in to the amp via HDMI works fine, I get a picture on the TV!
    However the 360 which i have connected to the amp via component, does not seem to output video through the hdmi cable connected to the TV!
    IS this correct? can it not convert the component signal in to a hdmi signal ?
  2. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
    i think i read maybe it will only take 720p via component and convert to HDMI.
  3. garagekru
    garagekru
    Oct 14, 2007
    23
    3
    will give that a try tomorrow, do u know if it can allow me to take a normal scart connection (phonos) and send that over the hdmi to the tv?
  4. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    I think you are going to be disappointed, the sort of features you are looking for don't tend to come on the lower end amps that effectively only offer HDMI switches built in.
    This one doesn't even process audio over HDMI so expecting it to handle signal conversion to HDMI is a bit hopeful.
    If you have component inputs you are going to need a component output.
    Higher models in the Sony range can do what you want though.
  5. garagekru
    garagekru
    Oct 14, 2007
    23
    3
    ok fair play, is there no way to send the normal non hd sorcue (cable TV) along the hdmi cable?
    Oh Also can this amp be made 2 chan with a high wattage out put ?
    thanks for the help guys the manual is rubbish!
