Sony STR DE585 + PS2 Optial Link
Discussion in 'AV Receivers & Amplifiers' started by handers101, Apr 2, 2005.
Tags:
  1. handers101
    handers101
    Apr 2, 2005
    45
    11
    Hi , new to the forum, i hope this is the correct place, need a question answering if anyone can help,
    I Have just got an optical cable for my ps2 and just tried playing a dvd, the amp pics up the source, but will only play the audio through the front two channels and the sub, i cant seem to find anyway of getting the amp to play the dts or ddpl2 output from the ps2. does anyone know how to fix the prob or had a similar prob.
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
  3. handers101
    handers101
    Apr 2, 2005
    45
    11
    Thanks Looked at the setting and have now got dts working on dvd's still cant seem to get ddpl2 working on the games such as burnout 3
  4. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I assume you mean Pro Logic II ? If so i'd guess that it's then an amp issue rather than a PS issue.
  5. handers101
    handers101
    Apr 2, 2005
    45
    11
    Yeah the prologic II, oh well cant seem to find a fix, just seems odd that the amp can pick up the dts dvd output but not the prologic output from the games... its an odd one thats got me baffled and cant seem to find anyone options to play with lol, oh well :)
  6. Loewe
    Loewe
    Prologic surround is extracted by the amp from the stereo (2 channel) signal, if set correctly. From PS2 you can't get in-game DD or DTS, but PL (or PL2 for 5 discrete channels or PL2x for 6 or 7 semi-discrete channels!) works fine. Especially on Burnout, with cars passing by etc.
  7. Loewe
    Loewe
    Btw the amp doesn't know when the (stereo) signal is encoded with surround, so always have the amp on DPL, or "DPLII(x) Game" if you have this option, when you play games. Sounds good even on non-surround games.
  8. handers101
    handers101
    Apr 2, 2005
    45
    11
    so have the amp do the decoding of the 2channel source outputed by the ps2?
  9. Loewe
    Loewe
    Yes, the amp decodes the surround-sound encoded in the stereo-signal, if you tell it to do so. I only use analog connection, but should work fine and sound even better with digital (optical) connection. This is how you get surround from TV or VCR or other 2-channel surround-encoded sources too. All Dolby Surround sources/signals or decoders/amps are more or less compatible, but you should use the newest decoder you have (DPLII or DPLIIx) regardless the 2-channel surround source. For AV-use (TV/VCR/PS2 etc) you could/should leave the decoder turned on even on non-surround-encoded sources, except stereo music maybe.
  10. handers101
    handers101
    Apr 2, 2005
    45
    11
    Cheers For The Help :)
  11. punit12
    punit12
    Apr 20, 2006
    450
    28
    Watford
    +30
    this might be a long shot, but i was just reading this to get dts from my ps2 (in movies) but on the audio setup menu, only dd5.1 and mpeg2 can be changed; dts is in grey- and my dvd (elektra) suppsosedly has dts encoding?
    can anyone help?
    thanks
