Sony STR-DB940
Discussion in 'AV Receivers & Amplifiers' started by CLR7, Feb 9, 2009.
Tags:
  1. CLR7
    CLR7
    Feb 9, 2009
    3
    Hello there just a bit of advice really, is it possible for me to connect a sony SA-WMS7 active subwoofer to my STR-DB940 av receiver? if so could you please explain how as i'm having a bit of trouble..
  2. stblob
    stblob
    Sep 14, 2008
    1,821
    Portsmouth
    +426
    That's an old one now but you should have a single phono marked with sub out on the rear, connect this to the input on your active sub with a single phono to phone cable.
