Sony STR DB940 - Views/opinions.
Discussion in 'AV Receivers & Amplifiers' started by Nitesh9999, Sep 7, 2005.
Tags:
  1. Nitesh9999
    Nitesh9999
    Aug 31, 2005
    67
    Manchester, UK
    +3
    I just got one.
    Paid just under £100
    Specs...
    -Power output: 110 watts x 5 (8 ohms, RMS)
    -Decoders: Dolby Digital, DTS, Dolby Pro Logic
    -DSP modes: 27 pre-programmed sound fields, virtual 3D
    -Video inputs & outputs: 2 x video loop - with composite and stereo audio in and out, 3 x video inputs (1 front mounted) all with S-video, composite and stereo audio
    -Audio inputs: 3 x optical, 1 x coaxial digital; 5.1 channel external decoder, phono, 2 x audio tape loops, 1 x extra line input
    -Speaker outputs: 2 pairs (switchable) stereo audio, centre, rear - all 4mm banana/binding posts
    -Audio outputs: 2 x subwoofer; pre out for front, centre and rear; 2nd audio output for easy connection to a second amplifier, optical output, headphones
    -Remote control:
    -2 way full learning remote control with a large LCD display and macro-sequence facility
    -On screen display? Yes
    -Dimensions WxHxD / Weight: 430 x 161 x 405 / 13.2 Kg
    -Supplied accessories: Remote control, batteries
    -Extra: Built in RDS tuner, FM/AM reception, 30 presets; all connections gold plated
    So??...
    How much of a lemon is it?? :suicide: :D
    Be as brutal as you want, is it :smashin: , or :thumbsdow
    It was powerful thats all I really wanted. And at 110w/ channel 8ohm, it seemed decent enough.
    I only want it for a decent stereo setup for now (B+W 601 S3s I hope, if its up to the job, if I took it to my local SuperFi would they let me listen to the speakers through my amp??)
    Thanks for any input
  2. Bassbin
    Bassbin
    Mar 16, 2003
    2,395
    48
    Leicester
    +56
    Good solid buy for £100 as an AV amp. Some of them had problems with hiss but I owned one for several years and always enjoyed it. However, for hifi use I think you could do better for your money but try it against a budget rotel/nad/marantz amp when you go for a demo (Superfi should be fine with you taking your amp in).
  3. jwramsay
    jwramsay
    Sep 7, 2004
    1,622
    West of Scotland
    +70
    You bagged a bargain there! I just sold my Sony 930 for 160 quid, and the 940 is the newer model. The 930 was superb and very very powerful.
  4. doubledrat
    doubledrat
    Jan 24, 2004
    89
    just to make you feel good, I paid 400 for mine years ago :(
    good amp for cinema, but not brilliant for music imho
  5. Grimley
    Grimley
    Sep 19, 2003
    870
    Deepest, Darkest Essex, so BEWARE!
    +98
    I owned one up until last year - would have kept it if I didn't want 6.1 & PLII
    To sum up-
    Good Receiver :smashin: Awful remote :thumbsdow l
    Hope you didn't get one that hums or hisses though :)
  6. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    A good buy for £100 the 930 was better than the 940 ,i quite liked the remote, took me ages to used to my latest.
  7. Nitesh9999
    Nitesh9999
    Aug 31, 2005
    67
    Manchester, UK
    +3
    Thanks for the honest opinions guys.
    I'll take it down to Superfi and see what I make of it... :) I just hope its got enough grunt to get some loudness from the 601s. And I hope it isnt outperformed to much by the budget rotel/nad/marantz (although, even the budget amps cost £150+)
    Also what causes the hissing? Can it be repaired if it hisses? Would this be expensive?
    And the only thing I see me using the remote for is volume, so that shouldnt be much of an issue.
  8. Kryters74
    Kryters74
    Jul 23, 2004
    239
    London
    +7
    I have had one of these amps for years and I have never once heard any hissing, so hopefully yours will be 100% OK.
    Good luck with the tests!
  9. Nettand
    Nettand
    Paid a lot more than that for mine a few years ago.It has been trouble free and I was very happy with it. Certainly no hissing problem with mine. Just been damaged though and beyond repair so I am now looking for a suitable upgrade replacement.
  10. Nitesh9999
    Nitesh9999
    Aug 31, 2005
    67
    Manchester, UK
    +3
    Ok,
    I got it on Sat and its is huge!! And pretty heavy. And that remote is is a bit weird!! :confused: But it has a little screen which impressed the lads :rotfl: anyway...
    hooked it upto my dads old Aiwa hifi speakers, and it souned great, I couldnt hear any 'hissing' and the AMP was more than enough for the speakers can't remember the the specs of them), so the B+Ws should sound fine with it.
    I think i'll take it to SuperFi next monday.
