Sony STR-DB940 or Denon AVR-3801
Discussion in 'AV Receivers & Amplifiers' started by slateram, Mar 22, 2001.
Tags:
  1. slateram
    slateram
    I've seen both recommended in magazines, but also noted on this forum that some have had hissing problems with the Sony.
    Sony is lsited as £500 and the Denon £800, so it needs to be sigificantly better if I'm to go for the Denon. What do you think?
    Also, can you explain the difference between an Amp and a Receiver. Home Cinema Choice has this split whereas Home Entertainment calls them all Amps - I'm a little confused!
  2. JT
    JT
    Jul 18, 2000
    141
    +4
    I believe you can pick up the Denon for around the £600 mark, just do a search on this forum or have a look in the adverts in HCC. The difference between a Amp and a receiver is that a Amp does not have a radio tuner built in, whereas a RECEIVER has.
  3. pauld
    pauld
    There is no comparison, go for the Denon, it has full 6.1 in EX and DTS ES. I have this amplifier and have also heard the Sony on many occasions and the Denon wins hands down!!
  4. slateram
    slateram
    Thanks Paul and JT - Denon will soon have a new customer!
