Sony STR-DB930: Volume lamp stopped to work.
Discussion in 'AV Receivers & Amplifiers' started by asusamdxp, Jul 22, 2005.
Tags:
  1. asusamdxp
    asusamdxp
    I have a STR-DB930 Reciever from SOny and i had it couple years now and I love it. I have now encountered a problem and I need help. The volume wheel has a red light to show the position or the level of the volume, this lamp has stoped to work. the problem is when i turn on the reciever the lamp works for a second the stops to work. What can I do myself to fix this or must I take it to sany service center that will charge me alot of money?
    Please need help!
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Problems with this led are a common problem with this amp. Mine worked fine for the five years it was used. Others have not been quite so lucky. While the amp has value to you, its limited cash value may make a Sony repair un-economical. Only the technically competent would attempt their own repair.
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    I have the same amp and the same LED stopped working last year.
    I just make do, it's not exactly vital. Great amp though.
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    They all do that!
    100s of examples if you search
