Sony STR-Db930 Trouble - only 2-channel
Discussion in 'AV Receivers & Amplifiers' started by Will18, Apr 1, 2005.
Tags:
  1. Will18
    Will18
    Feb 1, 2004
    120
    My amp was working fine until i moved it from one room to another and now no matter what i do it is only playing 2 channel, ie when using the THX audio tests all the sound, front, centre and rear come out of the front two speakers and it is driving me insane. It is hooked up to a Sony dvp ns930v and maybe it is this that is causing the problem.
    Can anyone help
  2. Kryters74
    Kryters74
    Jul 23, 2004
    239
    London
    +7
    Have you tried any other sources ie TV, sat box etc to see if they are ok - you can set any of the 'sound field' surround options for this and it should use all the channels.
    I am sorry if i am teaching you to suck eggs...
  3. Will18
    Will18
    Feb 1, 2004
    120
    Just tried 21 Grams's DTS track and it works fine, but i'm only getting 2-channel on the star wars disc and also the THX optimizer, but n/m I never planned to watch star wars, only needed it for the THX optimizer
  4. Kryters74
    Kryters74
    Jul 23, 2004
    239
    London
    +7
    At least the amp and DVD player are OK.
    Nick
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    do a reset
    turn off amp, turn on amp holding "memory" (I think)
    amp goes into demo mode, switch off and on again
    amp now reset.
