Sony STR-DB930 Overheating!!!
Discussion in 'AV Receivers & Amplifiers' started by thudspud, Apr 15, 2002.
Tags:
  1. thudspud
    thudspud
    Mar 28, 2002
    2,399
    Sheffield
    +130
    Hello All
    I have had a Sony STR-DB930 for about three months now and when I first got it the speakers (Mission 771e's) were bi-wired and everything was fine.
    Now I have bought some QED silver Anniversary cable and couldn't afford the extra for the Bi-wire version :( When I watched a film at a reasonable ;) level (honest) for the first time with the new cable the amp clicked into protection mode after about two hours and I have to wait for it to cool down for ten minutes before it will work again, Any ideas why it is doing this??
    Chris
  2. Timh
    Timh
    Sep 14, 2000
    5,257
    3
    3
    Altair-4
    +339
    Does it have a cooling fan? if so, it may have stopped working :(
  3. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    Is it possible that the reason the amp is cutting out,is thermal overload caused by a stray wire from the speaker cord shorting against the case or across the terminals?
  4. Timh
    Timh
    Sep 14, 2000
    5,257
    3
    3
    Altair-4
    +339
    It is possible, but I would put back the old cable to test it for a while, but dont bi-wire it.
  5. mjn
    mjn
    May 24, 2001
    23,206
    Herts, England
    +11,425
    i have this amp, and it does get quite warm during use.
    Just make sure you don't block the vents at the top.
  6. thudspud
    thudspud
    Mar 28, 2002
    2,399
    Sheffield
    +130
    Hello
    Thanks for all of the responses, I will try them out tonight.
    It might be caused by the fact that I have the minidisc player and the DVD player on top of the amp!!!!
    Chris
  7. mjn
    mjn
    May 24, 2001
    23,206
    Herts, England
    +11,425
    that could well be it..!!
  8. thudspud
    thudspud
    Mar 28, 2002
    2,399
    Sheffield
    +130
    Hey all
    I tried the suggestions that were given and the problem seemed to go away :D until last night :mad:
    I wasn't watching anything loud, just listening to the radio at a low level then it suddenly cut out :(
    I have now raised the CD player up a little above the amp with four little blocks to give it some more 'breathing space' and I also went into Richer sounds Liverpool branch today and they had a large amount of QED Silver Anniversary in the 'Bargain Bin' so I have now put the speakers back to being Bi-Wired, Hopefully things will be fine from now on :confused:
    Chris
