Sony STR-DB930 Coaxial Connection Question
Discussion in 'AV Receivers & Amplifiers' started by hunkiemunkey, Sep 1, 2007.
Tags:
  1. hunkiemunkey
    hunkiemunkey
    Jul 17, 2002
    88
    Hello.
    I have the above receiver, and have misplaced the instruction manual, hence asking this question :)
    It only has 1 coaxial input and on the back it is labelled 'DVD Coaxial In' - I was just wondering if this could be assigned to another input, or is it limited to DVD?
    Many thanks in advance.
  2. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    DVD only if memory serves correctly. Pretty sure.
  3. hunkiemunkey
    hunkiemunkey
    Jul 17, 2002
    88
    Thanks for your reply, now I've sorted out my PC I shouldn't need to use the coaxial connection anymore. :thumbsup:
  4. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Cool. You CAN rename the sources as you no doubt know, as an alternative to assigning the connection.
