Sony STR DB930 2nd audio!!
Discussion in 'AV Receivers & Amplifiers' started by mick_smoo, Aug 19, 2003.
Tags:
  1. mick_smoo
    mick_smoo
    Hi all, Hope you can help cos I'm doin' my nut with this amp.
    I was messing around with it a couple of month ago and somehow have enabled the second audio source on everything to be TV/LD (my Sky Digital input) and now I can't get it off.
    When I listen to the CD player or anything else when the TV is on I get two audio sources mixed together. Any ideas????
    They are both on anologue inputs.
  2. FoxyMulder
    FoxyMulder
    Just click the mode button next to the function dial till it gets back to the original setting, i have the same amp as u.
  3. mick_smoo
    mick_smoo
    I've tried that and it doesn't work. I have put the second audio back to SOURCE. Even when I'm on the CD input and change the SECOND AUDIO to something else like MD/DAT it still allows Sky Digital audio to come through. Any ideas???
  4. mjn
    mjn
    May 24, 2001
    22,102
    Herts, England
    +9,855
    press the mode button on the front til "2nd audio" is shown, twiddle the dial until "source" is displayed, that should sort it out.
    However i thought, that the output only came out of the 2nd audio outputs at the back??!
  5. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    bit of a bummer this, but look in the manual and see if you can reset all settings.
