Sony STR-DB925 volume stopped working.
Discussion in 'AV Receivers & Amplifiers' started by Timh, Jun 12, 2002.
Tags:
  1. Timh
    Timh
    Sep 14, 2000
    5,203
    3
    3
    Altair-4
    +297
    My Amps volume has stopped reacting to my remote command, it started a fiew months ago but only intermittent. it just seemed to be the first 25% which got used the most, now its packed in all together :(
    Any ideas whats wrong? is it worth stripping down and cleaning the motor out?
    Thanks for any advice.
  2. Timh
    Timh
    Sep 14, 2000
    5,203
    3
    3
    Altair-4
    +297
  3. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    big downer tim.
    presumably the volume still works if you go up to the amp?
    have you tried doing a hard reset of the amp... sure there was a key press to do this.
    also, assuming you arent using a learning remote and just the sony supplied one... have you tried something else to control it?
    at least worth a try to confirm it.
  4. cutes6
    cutes6
    Jan 3, 2001
    793
    Near Leeds
    +26
    Tim if you like the amp like I do and yours is faulty - I have one for sale having upgraded.
    Let me know if you are interested and make me an offer
  5. Timh
    Timh
    Sep 14, 2000
    5,203
    3
    3
    Altair-4
    +297
    I had the cover of my Amp this morning, there doesn't look like much can be done, what the hell, I though I would have a go, I removed the Knob and then disconnected the circuit board that the volume motor was attached to, on closer inspection I found the motor was seeled, I didn't think it was worth attacking just incase the volume stopped working all together, it just meens I will have to get up to make any volume changes :( Damb Sony cheap muck :mad:
    I then put it all back together tried the remote and Yes! the remote volume was working, it must have just been a bad connection between the circuit board and where it plugs in :)
    No new Amp time then :( I really want to go for a Denon AVR-2802 but can't justify the expence when my Amp is working fine now :(
  6. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    glad you got it working.
    I switched from a Sony 925 to 2802 - big improvement... in both home cinema and stereo.
    also soon to be joining you with a Panasonic pj...(with supplies permitting).
  7. Timh
    Timh
    Sep 14, 2000
    5,203
    3
    3
    Altair-4
    +297
    You wont look back after having the Big picture :)
