Sony STR-DB900 or Cambridge Audio 540R??
Discussion in 'AV Receivers & Amplifiers' started by J4KCF, Mar 20, 2006.
Tags:
  1. J4KCF
    J4KCF
    Hi folks,
    I'm looking to enter into the Cinema sound market for the first time and I've been looking at the Sony STR-DB900 (£210ish) or the Cambridge Audio 540R v2 (£270ish).
    My other half is insisting the receiver is a slim design to fit into our furniture, hence the Denon 1906 etc are out the picture. I am open to any suggestions on Make and Model, as long as its silverish in colour and slim build.
    I'm looking at pairing it up with KEF KHT1005 or Mission M7s and in a few months a Denon DVD-1920 or similar. I'd ideally want to listen to CDs as well as watch DVDs, Sky etc and it will be connected to my Pioneer 436XDE.
    Your views, comments and opinions would be very much appreciated. :smashin:
    Thanking You
  2. J4KCF
    J4KCF
    Can anyone please give me advise on a slim receiver? And if possible, which of the speakers would be best?
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    I have the Sony STR-DB930 and it's very good.
    These are about £150 now and I can't fault it.
  4. chrisowe
    chrisowe
    Apr 17, 2003
    467
    Anywhere
    +16
    I have a STRDB930 for sale and it does sound excellent with the Kefs, it's not a slim design though unfortunately.:)
  5. J4KCF
    J4KCF
    Cheers guys, sadly the STR-DB930 aint an option, this is certainly a time where the missus says size matters and smaller the better!!! :(
  6. alphabet
    alphabet
    I don't know that Sony model, but have heard a few others and the sound did not appeal to me. On the other hand it may appeal to you, so do demo the units on your shortlist.
    As far as the CA 540R is concerned, I have had mine for close to a year(version 1) and I am really impressed by it, be it in stereo or HT mode.:thumbsup:
  7. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    Don't feel bad about missing on the 1906, the CA540r is way way better in the sound dept. Features are another story thou'.
    Re. the sony, no clue have not heard them!
  8. J4KCF
    J4KCF
    Cheers guys. Think I'm heading to Richer Sounds sometime soon for the Cambridge. Only found 1 review of Sony and not too bad, but, Cambridge seems a bit stronger. Can't demo Sony as its net only.
  9. Justhandguns
    Justhandguns
    May 5, 2005
    38
    11
    UK
    Found a few very short reviews about the STR-DB900 on the net, most people say it has a very 'digital sound'. The lack of connections is also a big issue as well. Also, you will find some tiny non-standard speaker connections as well. But the amp does look good.
  10. BobbyX
    BobbyX
    Jul 19, 2005
    78
    db900 is suppose to be rubbish a 3 star product check for reviews on home cinema choice website. Cambridge will be better sony 798 is also very good that would suit the kefs alot better then cambridge. Cambridge would work better with proper hifi speakers though.
