Sony STR-DB795, which speakers do I get?
Discussion in 'AV Receivers & Amplifiers' started by clarkstow, Oct 20, 2004.
Tags:
  1. clarkstow
    clarkstow
    What a great forum this is. It's the first time I have come across it, and I will definatly be recommending it. Now to my question.
    I am looking at getting a Sony STR-DB795, can anyone recommend which set of speakers I should get at the budget end of the market? :)
  2. TheeNoMaD
    TheeNoMaD
    Look at the mordaunt short setups there are various available and all are pretty good, or try and construct your own from missions m30 series m32's are pretty good value. Or if your budget can stretch to it the new wharfedale diamond 5.1 setup looks pretty tasty and won a what hi-fi award. Also you can buy another set of diamonds for around £150 to take it to 7.1 if you want to? Hope that helps but i wasnt sure on your exact budget.
