Sony STR-DB790 volume levels...
Discussion in 'AV Receivers & Amplifiers' started by rupbert, Dec 23, 2003.
Tags:
  1. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Hey guys, just took delivery of a new shiny STR-DB790 (purdy) and although my new Tannoy R2's have not arrived, I was impatient and integrated the amp into my current setup...
    Everything is set up correctly, and when using the fm/am radio the volume only needs to be around -50db to be deemed 'loud'.
    However, when I switch to tv/sat or dvd (both which are connected using generic phono leads) I have to turn the volume on the receiver to around -30db to get around the same level of output as the tuner...
    Is this a 'feature' of all receivers? Is this due to the dvd and tv being 'external'?
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    I'm guessing it's because the reception on the onboard tuner is of a very high sensitivity?
    Perhaps somebody else can provide a better theory!
    Dimmy
  3. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Well just connected my Xbox using digital to video 3, and the volume is as loud, if not louder than the tuner...
    I guess its the very poor (less than £1) phono leads...
    Off to the shops I go :)
  4. Clarkey
    Clarkey
    Dec 27, 2001
    140
    Manchester
    the output from my sky digibox is quite a low level even on maximum setting in the menu. DVD's are always quiet too, but thats just the nature of the soundtrack. Personally I wouldn't worry about it.
  5. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Hehe, it just scared me when I switched from watching Blawk Hawk Down at -33db, and then turned radio 1 on!!!
  6. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Found what the problem was, in the DVD setup menu was an option to switch 'Audio DRC' to 'wide range', hey presto hugely improved volume levels...
  7. mjn
    mjn
    May 24, 2001
    18,393
    Herts, England
    +5,477
    Don't agree with that! I find that a Cd player on an analogue input gives the quietest input (smallest signal), while my DAC (using the 5.1 bypass) gives the strongest signal.
    And that any digital input is also quite "loud" as you say.
  8. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    I find that most dvd's are more quiet than anything else.Most of the time the amp (sony) is around -50, ihave had dvd's upto around -35 , but this seems to be up and down and not the same for all dvd's.T3 is the loudest dvd i've heard.
  9. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Received my Tannoys this morning!!! Was told I was getting them Monday...
    Although not run in, the difference is staggering. The clarity of the sound, the smooth treble, and this is with carp speaker cable! Getting some QED Silver Bi-Wire on Saturday, cannot wait!
  10. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I have a Sony 1070 and Tannoy R2's. First at -35db's it is VERY loud, i could not listen to BHD at this volume. Secondly check your speakers are a matching pair, i.e 00013 + 00014 are matching 00014 + 00015 are not a matching pair.
