Sony STR-DB790 v STR-DB795
Discussion in 'AV Receivers & Amplifiers' started by wisomann, Oct 5, 2004.
Tags:
  1. wisomann
    wisomann
    Mar 9, 2002
    5
    Anybody know the difference between these 2 models. Also what speaker system would you recommend £500 budget. :lease:
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,226
    2
    +3,712
    The 795 has an extra channel taking the total to seven. The two are otherwise pretty similar.
  3. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    Yep. 7 channels so they upgraded the Pro-Logic from II to IIx, also 10W extra per channel and an extra co-axial digital in.
  4. TheeNoMaD
    TheeNoMaD
    For a $500 quid speaker set up i would suggest the Mission m30's its £400 for a 5.1 so see if you can get an additional 2 too use the full 7.1 of the Sony and bring the speaker total to £500. Then your PimPeD
  5. Sam1
    Sam1
    Aug 1, 2004
    Is it possible to connect a stereo amp to this receiver so that the front speakers can be used for both systems. Or would i have to look at a more expensive amp such as the Yam 750 for this feature.
  6. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    I don't think you can - the Sony doesn't have pre-outs.
