Sony STR-DB790 remote control problem
Discussion in 'AV Receivers & Amplifiers' started by samsuka, May 20, 2005.
Tags:
  1. samsuka
    samsuka
    Oct 29, 2003
    20
    3
    I have a Sony STR-DB790 receiver, which i am very happy with. However recently the remote control receiver has stopped working on the machine. I know the remote still works because it operates my tv and dvd player, and i also tryed to operate the receiver using my wifes pda remote control software, but to no avail.
    Has anyone else ever encountered this problem and is it something that can be fixed easily?
    Sam
  2. ben1
    ben1
    I to have a similar problem sam
    I recently bought an STRDB1070 amp and the remote wont operate the amp anymore but still illuminates the on remote display?
    Has anyone any experience of this or a solution please?
    Ben
    :lease:
  3. ben1
    ben1
    Sam
    Mine is fixed now
    I first cleared the memory of the receiver memory and then cleared the memory of the remote.
    No more gettin off my ass to work amp :thumbsup:
  4. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I have a 1080 ,i don't know if the remote is the same but i selected av system2 and the remote would not work the amp selecting av1 solved the problem.It would be better to do what ben1 did and reset the remote.
  5. samsuka
    samsuka
    Oct 29, 2003
    20
    3
    Hi bob1 and ben1,
    Fantastic, thanks. A good case of RTFM (Read The F###ing Manual) ;-), i can finally enjoy the joys of surround sound from the comfort of my sofa again
    Samsuka
