Sony STR-DB790 not detection Multi Ch. sound!?
Discussion in 'AV Receivers & Amplifiers' started by peterakastorm, Sep 22, 2005.
Tags:
Thread Status:
Not open for further replies.
  1. peterakastorm
    peterakastorm
    Hi everybody!
    Just got my Sony STR-DB790 hooked up to my Sony DVD player via coaxial cable, but I have a problem... The Reciever wont recognise the multichannel sound the DVD player is outputting... If I set it to autodetect, it only finds 2 channel sound... and I have doublechecked that the output from the DVD player is 5.1 sound...
    The strange thing is that I think it worked for a while... then I wanted to hear what it sounded like in those "Sound Fields" Sony has... and then I couldn't get surround... what's wrong?!
  2. peterakastorm
    peterakastorm
    Nevermind... Changed something in the setup of the dvd player, from D-CPM or something to Dolby Digital... :S Thougt that setting would be default!
Thread Status:
