Sony Str-db790 Help Needed
Discussion in 'AV Receivers & Amplifiers' started by forrestgump, Nov 7, 2004.
Tags:
  1. forrestgump
    forrestgump
    Oct 31, 2000
    1,428
    huddersfield
    +49
    had this amp for 9 months but never used the 5.1 audio outputs for dvd-audio or sacd until now, cannot seem to get the sub working when using the 6 seperate outputs from multi channel audio, checked all the cables, any ideas anyone
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Have you got it set up in Sony's menu settings that a sub is present ?
  3. forrestgump
    forrestgump
    Oct 31, 2000
    1,428
    huddersfield
    +49
    yes, tried all that, you can set it with or without a sub, the sub works fine in dolby digital and dts with movies and also with normal stereo music but not with multi channel
