sony str db2000 no sound when connected to satelite
Discussion in 'AV Receivers & Amplifiers' started by tonyspinks, Aug 18, 2005.
Tags:
  1. tonyspinks
    tonyspinks
    I have an str db2000 that works with everything except the satellite. I have two phono connections and they are in the right places on both the amp and the satellite receiver but no noise.
    I am a complete novice at this (took a week to put it all together!) so your help would be much appreciated.
    Many thanks - Tony
  2. tonyspinks
    tonyspinks
    Sorted it so dont reply! I only had to turn off the dvd and it all works fine.
